Message |
Has anyone ever had an issue with these transmissions? I know the common problem about 3 years ago was the input shaft bearing whine. I recently bought one to replace my old transmission, it is brand new ordered from concept z. Clutch disc and pressure plate are aligned correctly, the alignment tool slides in and out with ease. The transmission slides on right up until it hits the dowel pins and then just stops, almost like the dowel pin holes in the transmission aren’t big enough. My old transmission was easy to put on and take it off and this thing is being a pita.
